Browse Forums Paving & Concreting 1 Jul 16, 2009 10:34 am Hello, What is the best type of sand (washed, river, yellow?) to refill the gaps between brick paver that has gone due to weed removal, washing and those darn ants ? Should I recompact as well or just brush it in? Thanks for your advice. Re: Fixing Brick Paving 2Jul 16, 2009 7:59 pm pavelok it is a kiln dried sand with silicone in it designed for flexible paving. available from most paving suppliers Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Fixing Brick Paving 3Jul 16, 2009 8:35 pm davinci pavelok it is a kiln dried sand with silicone in it designed for flexible paving. available from most paving suppliers What happens when it gets wet, wouldnt the kiln dried thing be negated? Sand is silicone, Sio2 Re: Fixing Brick Paving 4Jul 17, 2009 2:06 am enarc Hello, What is the best type of sand (washed, river, yellow?) to refill the gaps between brick paver that has gone due to weed removal, washing and those darn ants ? Should I recompact as well or just brush it in? Thanks for your advice. Are you in Perth by any chance? It's kind of relative to preventing problems again after you redo the sand Re: Fixing Brick Paving 5Jul 17, 2009 1:31 pm Brickie davinci pavelok it is a kiln dried sand with silicone in it designed for flexible paving. available from most paving suppliers What happens when it gets wet, wouldnt the kiln dried thing be negated? Sand is silicone, Sio2 It gets lightly sprayed after being swept in and the silica makes the sand go "off". It still retains flexibility though, while sealing the joints more than plain fine sand. The pavers must be fully swept of any excess however as the silica can leave marks on the surface. Re: Fixing Brick Paving 6Jul 23, 2009 3:26 pm Brickie Sand is silicone, Sio2 To clarify: SiO2 is very different to Si, SiO2 is a very brittle compound as we know (in glass etc), Si is highly flexible and malleable (base for some sealants etc), hence it adds the moveability to pavelok. I've had some experience with Pavelok in a block of townhouses I lived in, the original paving was done with minimal sand base and on very clay rich soil. After a few years of rain and a massive F150 4wd going down it daily, the pavers cracked and came very loose, we pulled up the sections and put a new level base down and then swept pavelok over it when done. It was great for a year or 2 then went wobbly again - I guess it seems pavlok won't make up for a * install job but it does offer some extra reinforcement! Almost finished building the Ambrose + study villa with McCracken homes in Park Holme, SA. Only painting, stormwater, paving & flooring left then moving in. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9568 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8983 |
