Browse Forums Paving & Concreting Re: Prices for concrete???? 21Oct 10, 2009 4:31 pm Hi - I am in Adelaide South Australia. If I budget for $50 square metre for just plain concrete - the cheapest available - on rather level ground, possibly very very slight slope.......sand and clay soil...........would this be sufficient. I will need to have this laid by a concreter and would rather not call them out for quotes until I have the bulk of dollars needed saved. Am a student on extremely limited income - I have no idea whatsoever of the cost involved other than what I have read in this thread . Any advice much appreciated. I am looking for the cheapest type of 'flooring' possible for a backyard pergola - 20 square metres roughly - and concrete came immediately to mind. Only traffic will be human and a gas bbq, potplants - nothing major. HomeLover Re: Prices for concrete???? 22Oct 10, 2009 4:42 pm HomeLover Hi - I am in Adelaide South Australia. If I budget for $50 square metre for just plain concrete - the cheapest available - on rather level ground, possibly very very slight slope.......sand and clay soil...........would this be sufficient. I will need to have this laid by a concreter and would rather not call them out for quotes until I have the bulk of dollars needed saved. Am a student on extremely limited income - I have no idea whatsoever of the cost involved other than what I have read in this thread . Any advice much appreciated. I am looking for the cheapest type of 'flooring' possible for a backyard pergola - 20 square metres roughly - and concrete came immediately to mind. Only traffic will be human and a gas bbq, potplants - nothing major. HomeLover I too would be interested in an SA based price. I need to concrete a small shed 4x3m and would like it layed professionally. Re: Prices for concrete???? 23Oct 10, 2009 5:09 pm Hi, this might help... 20mpa concrete grey with delivery of 5k will cost approx 190 cu mtr + $1/k beyond 5k. So 2 x 190 plus 35 per sq mtr(20) About $1100+gst. Where you are coming from is where you are going to... Re: Prices for concrete???? 24Oct 10, 2009 5:22 pm onc_artisan Hi, this might help... 20mpa concrete grey with delivery of 5k will cost approx 190 cu mtr + $1/k beyond 5k. So 2 x 190 plus 35 per sq mtr(20) About $1100+gst. Thank you very much onc_artisan - and a very quick response! Gives me something to work with ............HomeLover Re: Prices for concrete???? 25Oct 10, 2009 6:29 pm onc_artisan Hi, this might help... 20mpa concrete grey with delivery of 5k will cost approx 190 cu mtr + $1/k beyond 5k. So 2 x 190 plus 35 per sq mtr(20) About $1100+gst. Hi onc_artisan.. what is the plus 35 per sq mtr for? Is that to get it layed? Re: Prices for concrete???? 26Oct 10, 2009 7:38 pm onc_artisan can I ask a question please? We are looking at getting 262m2 of coloured, stenciled concrete @ 25mpa with F82 mesh for driveway @ 4 inches thick and F72 mesh and 3 inches thick for the pathways, including 3 coats of sealer, we have been quoted $17,000 incl. GST, do you think these details sounds ok? Would it be much cheaper if we went with just coloured concrete and no stencil??? Thanks for your help. Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Prices for concrete???? 27Oct 10, 2009 10:07 pm In a word Pink, it would(should) be heaps cheaper The numbers you gave average out at about $67/sq mtr... Though doesn't tell the full story.(ie ??mtrs 4" and 3") I don't like to think about mesh being in 75mm of concrete...mesh needs a minimum of 45mm cover to avoid shadowing and possible concrete cancer (corrosion a while down the track). ...should have a minimum 45mm. Imagine placing concrete in the middle of 75mm thick concrete, ( a max of 32mm cover[-mesh thickness]) walking on the mesh, probably a barrow full of mud too, all designed to buckle and bend the mesh. adrian, the plus is for placing. This job will need 1 or 2 labourers a screed hand and a finisher for 2-3 days... Since the concrete is thinner it is no easier to finish, likely in fact to be more difficult. Where as a house pad of 262 mtrs will be formed and poured in 2 days, and if monolithic more setup time but less concrete shuffling Where you are coming from is where you are going to... Re: Prices for concrete???? 28Oct 11, 2009 9:12 am [quote="onc_artisan"]In a word Pink, it would(should) be heaps cheaper The numbers you gave average out at about $67/sq mtr... Though doesn't tell the full story.(ie ??mtrs 4" and 3") I don't like to think about mesh being in 75mm of concrete...mesh needs a minimum of 45mm cover to avoid shadowing and possible concrete cancer (corrosion a while down the track). ...should have a minimum 45mm. Imagine placing concrete in the middle of 75mm thick concrete, ( a max of 32mm cover[-mesh thickness]) walking on the mesh, probably a barrow full of mud too, all designed to buckle and bend the mesh.[quote] So you're recommending 100mm thickness for footpaths aswell as driveways??? What is an average price for * Coloured stenciled concrete? and * Coloured concrete? Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Prices for concrete???? 29Oct 11, 2009 9:25 am I priced a charcoal mix yesterday at $278 CU mtr yesterday The robbers... So a minimum of $27.80 a sq mtr just for conc.(100mm) We don't do stenciled so barlese on that. Where you are coming from is where you are going to... Re: Prices for concrete???? 30Oct 11, 2009 2:42 pm Are there any concretors out there that can tell me what you charge per m2 for the following... Supply all materials and labour for 100mm thick, F82 mesh coloured concrete and stenciled??? 100mm thick, F82 mesh coloured concrete??? Just for a rough guide to help me out please. Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Prices for concrete???? 32Oct 11, 2009 6:06 pm It depends where you are. (Conc prices and transport) But considering 12 sq mtrs would need 1.2 cu mtrs of conc @ $200ish plus $35 sq mtr for labour, a sheet of mesh and a few beers... Prolly 800 ish Where you are coming from is where you are going to... Re: Prices for concrete???? 34Oct 11, 2009 6:26 pm Up and down depends on size, use, colour, texture/finish etc. ...prolly only one guy on that one Where you are coming from is where you are going to... Re: Prices for concrete???? 35Oct 13, 2009 6:50 pm We just got a quote for our concrete (paths, alfresco, driveway and crossover) and I am just about to book myself in to get therapy-----$33,000 !!!! We don't know quite what to do, our WHOLE slab with 89 cubic mtrs of concrete and 5 tonne of mesh was less than this !! Re: Prices for concrete???? 36Oct 13, 2009 7:13 pm vid - it is not the volume that counts it is the area 89 cu mtrs is a lot of conc, worth about 18000, +3000-4 of steel. labour would have been 8-9000k... consumables 1500 = $32k plus the builders margin I think you got a bargain for your slab if it was less Where you are coming from is where you are going to... Re: Prices for concrete???? 37Oct 13, 2009 7:36 pm If anyone in the S.E of Melbourne wants a referral for a good concreter, please PM me. Their rates are reasonable and more importantly their work is neat, tidy and very professional. I highly recommend this concreter and he is very easy to deal with, especially if a female has to organise it all... like I did Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: Prices for concrete???? 38Oct 13, 2009 8:01 pm onc_artisan vid - it is not the volume that counts it is the area 89 cu mtrs is a lot of conc, worth about 18000, +3000-4 of steel. labour would have been 8-9000k... consumables 1500 = $32k plus the builders margin I think you got a bargain for your slab if it was less This is the quote: Plinths $6800.00 Paths $7500.00 Alfresco $3800.00 Driveway/Crossover $6800.00 Excavations $2800.00 Concrete pumps x 2 $1600.00 TOTAL $29,300.00 + GST Re: Prices for concrete???? 39Oct 13, 2009 8:28 pm Sounds like alot of concrete, how many m2 is this quote for? vid onc_artisan vid - it is not the volume that counts it is the area 89 cu mtrs is a lot of conc, worth about 18000, +3000-4 of steel. labour would have been 8-9000k... consumables 1500 = $32k plus the builders margin I think you got a bargain for your slab if it was less This is the quote: Plinths $6800.00 Paths $7500.00 Alfresco $3800.00 Driveway/Crossover $6800.00 Excavations $2800.00 Concrete pumps x 2 $1600.00 TOTAL $29,300.00 + GST Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Prices for concrete???? 40Oct 13, 2009 9:43 pm pinkfairymagic Sounds like alot of concrete, how many m2 is this quote for? vid onc_artisan vid - it is not the volume that counts it is the area 89 cu mtrs is a lot of conc, worth about 18000, +3000-4 of steel. labour would have been 8-9000k... consumables 1500 = $32k plus the builders margin I think you got a bargain for your slab if it was less This is the quote: Plinths $6800.00 Paths $7500.00 Alfresco $3800.00 Driveway/Crossover $6800.00 Excavations $2800.00 Concrete pumps x 2 $1600.00 TOTAL $29,300.00 + GST Not sure how many m2 in total, the only thing I do know the size of of is the Alfresco as we have had a tiling quote for 44m2. Tradie may sit at home but will need to get house plastered as well or will you sit it out? 6 10063 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 11026 |
