Does anyone know someone who does quality liquid limestone work NOR perth?
Has anyone had problems with liquid limestone?
Browse Forums Paving & Concreting Re: Liquid Limestone 2Jun 05, 2009 7:20 am try using the "search" function - plenty of results for "liquid limestone" After 4 years - we're in! Re: Liquid Limestone 4Jun 05, 2009 8:38 pm Can anyone tell me if you should go with the mesh in the driveway for liquid limestone as have had conflicting info when getting quotes. One has advised you need it and one says not to as it would rust but I could go for galvanised mesh but this is pricey.. Help! Re: Liquid Limestone 5Jun 05, 2009 10:07 pm Depends on your driveway... Where you are coming from is where you are going to... Re: Liquid Limestone 6Jun 06, 2009 8:28 am all concrete needs reinforcement for tensile strength ie: so it reduces the likely hood of cracking and if it does crack stops the conc. from separating Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Liquid Limestone 7Jun 06, 2009 1:43 pm davinci all concrete needs reinforcement for tensile strength ie: so it reduces the likely hood of cracking and if it does crack stops the conc. from separating Thanks for your advice. I will make sure I go with someone who has included mesh in there quote. Re: Liquid Limestone 9Jun 07, 2009 11:58 pm cheetah let us know what quotes you come up with, Im in perth NOR and will be building soon Sure. Im looking at doing approx 153m2 at a cost of around $10,200. This includes my driveway pathways and large area at front door this also includes bobcat hire to rip up part of an existing cement driveway and tip/bin fees. Try the search function on this site as suggested above. Re: Liquid Limestone 10Jun 08, 2009 12:45 am Does that include sealing? Where you are coming from is where you are going to... Re: Liquid Limestone 12Jun 09, 2009 9:57 pm Sweet Where you are coming from is where you are going to... Re: Liquid Limestone 13Jun 10, 2009 7:36 pm Yay! Approved quote today for driveway etc and am looking forward to it all happening in about 4 weeks. Could have it done sooner but need to have the wall built first across the front garden and then they can do driveway. Ended up costing $10,000 exactly with a bit of haggling for 125m2. Quite pleased as this includes the soakwells, sealing, bobcat, bin hire for debris, spray clean and prep for sealing, flexifoam between house and limestone and the galvanised mesh. Thank god this parts sorted! On to the next project. Re: Liquid Limestone 16Jun 23, 2009 10:53 pm I finally have the finished product down but due to bad weather am looking at another week with not being able to park on the driveway. Still needs to be sealed.
Very happy with it all. Looks great against the dark brick on the house. |
