Browse Forums Paving & Concreting 1 May 26, 2009 6:03 pm Just a quick question: How long we have to wait until a new plain concrete driveway is allowed to be used? Re: when new driveway concrete be ready? 2May 26, 2009 7:50 pm Most concretors will recommend you stay off with your vehicle for 10 days or so. You can walk on it the next day, but carefully as it can scuff up the surface. Concrete goes hard overnight but it's the curing that takes time and makes it stronger. The longer it takes to cure generally means it will end up stronger also. In warmer weather it is recommended to keep it moist or covered to stop it drying too quick. Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15793 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9862 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10940 |
