Browse Forums Paving & Concreting 1 May 07, 2009 2:27 pm Hi Guys, After trying to get several quotes (unsuccessfully) on getting concrete footings laid so a small 5-6 brick high retaining wall can be built, ive decided to do the footing myself. Ive got a few questions which i hope people can help me with. 1/How thick should the footing be? 2/as well as crushed rock, is reo required? 3/ MPA recommendations? Thanks in advance for any help. Also if you know a concreter/bricklayer in the Taylos Hill area which is willing to give me a quote on either brick work, concreting or both, please send through their details. Re: Footing questions 2May 07, 2009 7:52 pm 5 course high brick wall single skin --- 150mm wide x 300mm deep buy 3f11 trench mesh and cut off 1 x run of the y12 deform bar, the reo should be in 3/4 to the top of footing 5 course double skin no core fill --- 250mm wide x 300mm deep use 3f11 trench mesh in top 3/4 both above no back fill with back fill 5 course high double skin only, 250mm wide x 400mm deep with 3f11 trench mesh in top 3/4 and y12 deform bar in internal cavity @ max 500mm cntrs core fill with conc. footing should be min conc. mix 25/14/80 (when you book conc. just ask for the mix 25/14/80 but at best use a 25MPa footing mix @ 80 slump all double skin brick walls need brick ties every second course rendered walls need internal tanking where back fill touch's and damp course no crushed rock on strip footings or pier footings Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Footing questions 3May 13, 2009 2:23 pm Hi Davinci, Thanks for the advice. Ive already started digging out the area which is a hard task itself. Sorry for my lack of understanding but can you please explain the following questions: 1- What do you mean by y12 deform bar in internal cavity @ max 500mm cntrs core fill with conc. If i have trench mesh in the conc, where does the deform bar need to go? 2- What is internal tanking where back fill touch's and damp course? 3- Also the footings will have step downs as it will run along a step pathway. Apart from boxing up the step downs, is there anything else i need to do in this area to tie together the concrete? thanks. Re: Footing questions 4May 13, 2009 6:30 pm Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7298 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10207 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3300 |
