Browse Forums Paving & Concreting 1 May 04, 2009 6:20 pm We've got a battleaxe block with adjoining easments that are 100m long. After advice on what sort of driveway is going to be the most cost effective and look half decent. Any ideas on how much on costing would be most useful also. Here' a pic of how it currently loocks driveway_small.jpg Neighbour has the concrete bit on the left and ours is the grass on the right. Ideally would have a shared driveway. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Re: Advice on 100m driveway 2May 10, 2009 12:48 am 100mtrs x 3mtrs = 300 mtrs @ 100mm = ~$22,5k concrete grey (30 CU mtrs conc) ~ $30k exposed agg brick paving, don't do it! ~ $12k crusher dust 100 x 4.5mtrs plus 50% of above (45 CU mtrs conc) hope this helps this is a guide only and you may have site costs or deductions Where you are coming from is where you are going to... Re: Advice on 100m driveway 3May 10, 2009 7:34 am Thanks for that Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Re: Advice on 100m driveway 4Nov 01, 2009 9:53 am Hi - what did you decide to do in the end? Is it now finished? Build Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=43846 Re: Advice on 100m driveway 5Nov 01, 2009 7:07 pm Still have't decided...house is still being built so we have a bit longer to make our minds up Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Re: Advice on 100m driveway 6Sep 23, 2010 6:27 pm Still battling over this.... I'm currently leaning towards Bitumen. I read conflicting stories..so here what I'm thinking... I want something - that if it needs it can be repaired and would look ok repaired (here's where I think Bitumen would work) - Will stand up to water run-off - Will stand up to a small underground spring that leaves the area wet for about a week after heavy rain - good on steep slopes - durable Any advice on bitumen over concrete? Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Re: Advice on 100m driveway 7Sep 24, 2010 11:52 am The last 2 houses my parents lived in had 50m driveways.. both times the driveways were redone when they lived there. The most recent was bitumened (this was early 90s). The one before was paved! (that was in the 80s, to a Victorian era house, so perhaps there were some aesthetic reasons for that one ...). Built 3br house in Glenorchy, Tas in 2001 * * * Built 5br courtyard house in Lenah Valley, Tas in 2011 - Homeone thread / Blog I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9968 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18277 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 |
