Browse Forums Paving & Concreting Re: Coloured Concrete Driveway - Top layer or Coloured Through? 22Aug 22, 2009 10:42 pm Where you are coming from is where you are going to... Re: Coloured Concrete Driveway - Top layer or Coloured Through? 24Aug 23, 2009 3:43 pm Where you are coming from is where you are going to... Re: Coloured Concrete Driveway - Top layer or Coloured Through? 26Sep 02, 2009 11:41 am Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: Coloured Concrete Driveway - Top layer or Coloured Through? 28Sep 02, 2009 4:48 pm Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: Coloured Concrete Driveway - Top layer or Coloured Through? 29Sep 04, 2009 12:07 am Where you are coming from is where you are going to... Re: Coloured Concrete Driveway - Top layer or Coloured Through? 30Sep 17, 2009 9:37 pm Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: Coloured Concrete Driveway - Top layer or Coloured Through? 31Sep 18, 2009 1:41 pm I am in exactly the same possition trying to work ourt if I used coloured concrete all the way through or just on top with the colour sealer. I have been told 4 different opinions by 4 different concreters. Do i need to colour seal conrete that has the colour all the way though? Gee I wish that the concreters all told me the same info so I could compare apples and apples! If I have to seal colour all the way through concrete and also the colour on top..... why would you bother paying the more expensive one? *****FINISH BUILDING SOON!***** Re: Coloured Concrete Driveway - Top layer or Coloured Through? 32Sep 19, 2009 10:17 pm Trowel on oxides weaken the surface of the concrete as it replaces/extends cement. Premixed is prefered in my book and less likely to be subject to colour variation. Where you are coming from is where you are going to... Re: Coloured Concrete Driveway - Top layer or Coloured Through? 33Sep 21, 2009 8:41 am onc_artisan Trowel on oxides weaken the surface of the concrete as it replaces/extends cement. Premixed is prefered in my book and less likely to be subject to colour variation. Thats what I thought so if sealing is not to expensive I will run with that. Can you tell me how often a coloured drive needs re-sealing? Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: Coloured Concrete Driveway - Top layer or Coloured Through? 34Sep 21, 2009 8:12 pm That depends on the site.. ie: sunny, weather, traffic. But prolly every few years Where you are coming from is where you are going to... Re: Coloured Concrete Driveway - Top layer or Coloured Through? 35Sep 21, 2009 9:42 pm onc_artisan That depends on the site.. ie: sunny, weather, traffic. But prolly every few years No worries, I think I can deal with that Thanks for the advice Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: Coloured Concrete Driveway - Top layer or Coloured Throu 36Mar 24, 2012 5:47 pm We went for full depth coloured concrete because coloured top coatings require regular (at least every two years) reapplication to keep it looking good. Our professional concreters prefer working with Hanson concrete so we went for Hanson's Mocha because we wanted an Earthy brown colour. Within three days of being finished off it was bright salmon pink. Neighbours commented that it was an eye sore and one neighbour asked when we were going to raise the gay flag. I emailed pictures to Hanson and they didn't contact me back but they did contact my concreters. They have agreed supply several drums of sealer which should give it a darker "wet look". We have been saving up the money for ten years to concrete our driveway and what should have been a great project has turned out to be a very stressful experience for us. Re: Coloured Concrete Driveway - Top layer or Coloured Throu 37Mar 29, 2012 10:24 am Unless your a fan of bold colours for your house then, colour through is the way to go. Its finicky so you need a smart concretor. Also I would use a bagged oxide from a reputable company, Ability chemicals I have found to be the best. Hanson uses liquid colour in the concrete. I find it far more unreliable. Also the colour chart in their brochure is way off the real product. Colour on can last a long time but its so often applied poorly, ie when the concrete is too wet, may be easier on the day but trowelling all the water in leads to a weak surface and the colour wearing off in the future. DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17382 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 11000 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7346 |
