Browse Forums Paving & Concreting 1 Apr 20, 2009 9:13 pm Hi all, Has anyone used or had exp using thermacell blocks for swimming construction or perhaps bessa bricks have been looking at costsusing these methods alot cheaper than conventional spraycrete systems. Re: Swimming pool 2Apr 22, 2009 5:30 pm wont pass engineering, also you need a pool builders licence to build a pool, pools are concrete for a reason Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Swimming pool 3Apr 22, 2009 8:06 pm davinci wont pass engineering, also you need a pool builders licence to build a pool, pools are concrete for a reason Have spoken to thermacall Aust have sent alot of info as they have built a number of pools using their blocks in victoria. Just wanted some independant info not bad news!!!!! Re: Swimming pool 4Apr 23, 2009 7:07 am was referring to besser bricks not thermacall?, havnt seen thermacall? before, was assuming by question you wanted to build pool yourself, the company you have mentioned is most probably licenced to build pools but check anyway also fiberglass is fine they just cant sit empty in the ground for to long as they can crack on the base and side can bow in from neg. hydro pressure Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Swimming pool 5Apr 23, 2009 9:50 am Thanks , May end up going fglass as they are getting cheaper 7 mtr x 4 mtr kits now around 10 k plus delivery The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy… 2 4329 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11915 |
