Browse Forums Paving & Concreting 1 Jan 27, 2009 9:30 am Hi all,
I would like to get a concreter to do my driveway in exposed aggregate as our builder only offers coloured concrete but we prefer the look of exposed aggregate. Is there anything that i should make sure the builder has done or not done so that i can easily add the exposed aggregate after handover? Thanks for your help. Re: What do you need to cater for if getting external concreter? 2Jan 27, 2009 9:03 pm I think that the people you get will do everything. Get some quotes from a few companies to see the costs and ask them if your builder can do anything to reduce the cost they are quoting. Re: What do you need to cater for if getting external concreter? 3Jan 27, 2009 9:23 pm As part of your site clean, get as much leveling and cleanup done as possible, this will help reduce excavation costs. Also put in a 90mm pipe under the driveway locaton do you can run irrigation or power under the driveway. Adrian B Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 2654 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 11235 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 9158 |
