Browse Forums Paving & Concreting 1 Jan 13, 2009 4:40 pm I'm building an outside raised deck. Its about 500mm high. Its has double brick walls and I've solid filled it.
Originally I was going to concrete the top and then tile it, but Ive changed my mind and want to pave it. My question is, should I lay a thin concrete slab and then pack in fine bluemetal, or would it be ok to consolidate the fill and then pack in say, 300mm of bluemetal and then bedding sand? Re: Paving question 2Jan 14, 2009 6:39 pm all paving should be laided on a concrete base min 80mm thick, if slab is poured over fresh fill then there may be a need for piers for slab support
all fill should be dense compacted every 100mm in depth ( ie: layer compaction) Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12586 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5796 |
