Browse Forums Paving & Concreting 1 Nov 24, 2008 9:06 pm hi all - we have a very steep, short driveway that's only a few months old. it has grey tint through it, but looks awful (it's gone pale-like) and we want to coat it with something that will make it look wet, but grip is really important.
can anyone share any products that they've used (preferably DYI). thanks in anticipation. Re: Sealing very steep concrete drive 2Dec 05, 2008 11:33 am Hi there,
I'm guessing you have coloured concrete. You need to treat it first before you seal it. What you are discribing 'pale like' is what happens when you have trapped moisture. You will need a professional to come in and acid wash your driveway to bring back the true colour and then apply a sealer to seal in the colour for years to come, if you skip the acid wash your going to seal in your pale patches and will be expensive to repair. Re: Sealing very steep concrete drive 3Dec 05, 2008 11:35 am One other thing- you say your driveway is only a few months old. In that case you should call back the builder/contractor who did the job to repair the issue of the trapped moisture under, you should also check if you had this job done with a contractor that you organised if sealing was included in the price (or check with builder). Re: Sealing very steep concrete drive 4Dec 05, 2008 4:40 pm pale like may be be lack of sealing not moisture, subsurface moisture can cause effervescents, effervescents looks like a white powder (very fine ) on surface
if the concrete was sealed with a xylene based sealer when wet and it then went pale, acid both hydro or oxcylic wont fix it the solvent and moisture reacted and went milky (stained) concrete oxides or hardeners are not uv stable and fade quickly if not sealed if it is a lack of sealer then acid clean drive and seal with a coloured xylene based sealer Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Sealing very steep concrete drive 5Dec 05, 2008 8:26 pm thanks so much for you replies. when we originally had the drive done (council done - long story!) it did bleed salts, but this isn't the current issue i have. this really is a all-over consistent 'bleaching' like a fade - to my female eyes it looks as if it needs some lovely moisturisor on it's dry skin!!! so i think the acid wash etc that davinci suggested might be the go.
any ideas how much this would cost for a 3mx10m?? thanks so much in advance - really appreciate it. Re: Sealing very steep concrete drive 6Dec 05, 2008 10:32 pm if you do it yourself around $30 for acid and $120 for coloured sealer Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Sealing very steep concrete drive 7Dec 06, 2008 7:58 am that sounds pretty reasonable - my concern would be, will the sealant make the driveway slippery in the wet -- this is a VERY steep short drive -- are there particular sealants that don't get slippery that you know of? Re: Sealing very steep concrete drive 8Dec 06, 2008 4:57 pm get a penetrative sealer not a surface sealer (not from bunnings etc)
goto a concrete product suplier store like slate-crete or faux-brick concrete product suppliers will also have a non slip additive for sealer , for extra grip use a roller or broom for application in two coat stages 50/50thinned out first coat for deep penetration and then a 20/80 second coat or as per manufacturers recommendations Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Sealing very steep concrete drive 10Jan 06, 2009 8:41 am There is an acid etch product that you can buy from Bunnings (cant remember name but its approx $15 and in a white plastic container.
Easy to use, all you do is dilute the powder in water, and spray on concrete with a pump garden spray (try to get a cheap one with all plastic parts ($10 from The Warehouse/Sams), and dont forget to rinse pump thoroughly straight after use) Also, give the concrete a light spray with water before spraying with product as this will prevent the product getting absorbed to deep into concrete (this part isnt on instructions but i figured it out after i started spraying) leave on for about 10-20 minutes (just keep checking concrete to see if its etched enough) (you can also add small amounts of water whilst its reacting and use a broom to spread it more evenly around )and when your happy rinse thoroughly with lots of water(buy a $10 squeegee on a pole to aid with rinsing). Its quite easy to do as this product is fairly mild, but still take precautions ie eye protection, rubber gloves & boots. Just remember that you have to move quickly so do it in small parts about 15 sq m and use a friend to brush whilst you spray. ![]() No. The outcome of the meeting would be a permit provided by council(if they agree) which would be valid for 12 months. If the driveway is not constructed be fore 12… 6 7588 Hi El Forgo From what you are describing, I would be budgeting at least $6,000-7,000/sqm at an absolute minimum, possibly even $8,000. This factors in: 1. The sheer… 4 13944 ![]() DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 15529 |
