Browse Forums Paving & Concreting 1 Oct 21, 2024 2:16 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I need to skim coat some brick steps I cut away when I built a new deck. The brick and the concrete are virtually at the same level. I'm not concerned about how it all looks; just looking to seal up the bricks from storm water which will pass over them in heavy rain. I was thinking of usuing cement, but would it be too thin of a coat and crack straight away? Any ideas about how to seal off the brick are very welcome! DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 10438 Thanks for that. I think the mortar has been sitting on these surfaces for approx a year. We’re at handover & they tried to get it off the rubber but have damaged it… 3 6971 DIY, Home Maintenance & Repair I do it all the time - units, mm/m, kpa/mpa etc and I still get on google and check it - it's easy to be out by a factor of 10, 100 etc 5 8277 |
