Browse Forums Paving & Concreting 1 Oct 16, 2024 6:14 pm Howdy, I'm trying to figure out the best way to go about pouring a concrete path next to an old house. I've been told conflicting things- drill rebar into the foundations, and don't drill into the foundations. I'm not really sure what do to. I've attached a couple of diagrams, the red indicates the rebar, the blue the mesh that would get attached. I was thinking the mesh and rebar would sit inside the new concrete. There are vertical facades on one side of each path. Would it be beneficial to put a membrane down also? Thank you! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New concrete path attach to foundation? 2Oct 16, 2024 7:15 pm Don’t drill into habitable slab or habitable slab footings as the path and residential habitable slab moves differently. In actual fact you need isolation joint in between the path and house slab with Abelflex or similar. Generally you also need to have control joints at 3.0m maximum spacing. Also no need for membrane under external path as moisture ingress can accumulate between the bottom of path and membrane. Re: New concrete path attach to foundation? 3Oct 16, 2024 8:16 pm Eng. B A Don’t drill into habitable slab or habitable slab footings as the path and residential habitable slab moves differently. In actual fact you need isolation joint in between the path and house slab with Abelflex or similar. Generally you also need to have control joints at 3.0m maximum spacing. Also no need for membrane under external path as moisture ingress can accumulate between the bottom of path and membrane. Thank you for this! I started drilling the holes (white dots) but I guess I'll just fill them in. So I would glue the abelflex to the footings and then the poured concrete will adhere to it? Building Standards; Getting It Right! Make sure you don’t dig below footing base level, so you don’t undermine your foundation. Also the backfilling of trench need to allow for stormwater to drain away… 1 8899 Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 10448 Hi all, It appears they have cut and jackhammered the house footing for a service they were planning to run? Will there be any potential structural issues? Noting that… 0 8883 |
