Browse Forums Paving & Concreting 1 Jun 02, 2024 2:54 pm Hi all, We had concrete included around the perimeter of our house as part of our new build, including paths and a patio under pergola. The patio slab is dusting and parts of the cove finish can be rubbed of with just my hand. We have received conflicting advice about how to remedy it. Independent concretor says surface needs to be gound down before any resurfacing or rectification. Concretor who did the job wants to use hardener and then resurface (product looks a bit like render). Any suggestions on how to remedy this? We are overall really unhappy with the job. It's rough all round and we already compromised with the contractor as our drveway ended up two different colours! Thanks heaps! Re: Rain damaged concrete causing dusting 3Jun 02, 2024 10:03 pm ![]() Want rough surface for ‘rende/leveller’’ to grip, best Get scope of works, original concreter has opportunity to remedy Thanks, we are headed in the direction of grinding, but unsure of what to do on top of that? The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 20109 ![]() 4 21045 |
