Browse Forums Paving & Concreting 1 Aug 11, 2023 2:44 pm Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path around the perimeter of the house, as we are on clay soil. The house slopes gradually from left to right and towards the back too as you will see in the pictures. Not sure if we should wrap around the corner with stairs or what is best? Any suggestions would be very helpful. Thank you Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all. I have a drop edge beam down the left side of my house. Across the front the drop edge beam is approx 1m on the left and fade to normal ground level on the right… 0 6685 You need to refer back to the structural engineering footings and slab design for edge beams depth. The depth on reactive clay doesn’t necessarily depend only on bearing… 1 9208 Generally you don’t need supporting piers/blocks under garage/non-habitable floating GROUND slab (That has no load bearing structures over) if it has good soil bearing… 2 8543 |
