driveway f62 steel ok?
https://forum.homeone.com.au/viewtopic.p ... 542#118542
davinci
From mpa strength is dependant on the agg. mix you choose.
25 mpa is the starting point for trafficable conc.
32 mpa for stone below 7mm and or glass agg.
32-42 mpa for terrazzo weather grind and sand blast or polished
min. drive reo = rl62 for standard vehicles
rl72 for medium vehicles (4x4)
rl72 for light commercial as well
rl82 for heavy commercial
rl92 for light industrial
double rl92 heavy industrial
Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am…
2/05/2023
1
You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would…
19/05/2023
Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you…
