Browse Forums Paving & Concreting 1 Mar 28, 2022 9:31 pm Hi Guys, TLDR: How would I restore a sandstone/limestone (?) slab so that I could lay interior flooring. What kind of surface prep and would self levelling concrete work? Also what is the material that is used for the slab? I have a standalone structure (5m*4m) that has previously been used as a shed that I now want to renovate it into an additional room. The slab is not in the best condition and it is made out a sandstone/limestone kind of material instead of concrete. The paint comes off when it so much as touched. It seems like there are two layers separated by a sheet of plastic if that is any sort of indication to the type of material used. There are also several deep cracks along it. So how would I go about restoring it? I have looked into self levelling concrete and seems like it could be a valid solution although I am a complete newbie and I may be missing something. How would a prepare the surface? What type of sealant and the like. At the moment my thought process would be to; 1. Remove the existing paint. 2. Sand down obvious bumps. 3. Apply a sealant and bonding agent. 4. Apply self levelling concrete. 5. Lay interior flooring. Does this sound about right? Thanks, Caleb Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3061 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12469 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11626 |
