Browse Forums Paving & Concreting 1 Aug 24, 2021 11:55 pm Hi All, I would like some advice about building a bench/seat next to my pool. The plan is to try my hand at a DIY job (cannot afford to pay someone). The bench would be about 5 meters long, 50 cm high and 50cm deep. It would be against a shed wall so only needs to have one side and the top with panels. My plan is this: * Dig 6 holes and put in some stainless steel stirrups. (stainless as next to pool which is salt water) (2 each end and two in the middle) * Fill with concrete - as there will only be 50cm between each pair of stirups, the concrete would be joined up for both. * Use some 90mm posts (very short) and then some other framing pine wood to make a structure * Attach some fake wood decking boards to the side and top. (3x140 on the side and 3x140 on the top) * The frame nor boards would not touch the shed at all. My problem is that when I have started digging down, there are some pool pipes, vine roots in the way as per the photo. I am unsure if i can simply pour concrete right over all this and it will both hold it's strength and also not crack/affect the pipes over time. Would I need to wrap the pipes in some type of foam insulation to allow for a little bit of expansion etc ? (the pipes might have 50C water from the heating). Should I chop away the roots or would they be ok (as i like the vine). I suspect also that I will need to dig down deeper - maybe 30cm or so? Should i try and attach to the concreate on the shed slab or pool tiles slab or just have it free standing? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 843 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9174 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
