Hi all,
Just wondering whats the quickest/easiest way to remove splatter from coloured concrete on weatherboard walls?
Or do I just use a bit of elbow grease and go at it with a rag/brush?
Browse Forums Paving & Concreting Re: Cleaning of coloured concrete splatter from weatherboard 2May 14, 2021 5:57 pm You can also try WD-40. Perform a spot test in a non-obtrusive area first before applying it to the walls.. No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4923 We have a new build and need to clean bricks around a newly constructed deck. Need advice about whether to clean bricks with acid prior to oiling the deck, or should we… 0 2582 |
