Browse Forums Paving & Concreting Re: Surface cracks immediately in new concrete driveway 21May 03, 2021 2:39 pm I would never leave a customer with that for a finished job, however as far as your rights go, I think they are allowed to walk away from it as its non structural. If they happen straight after the pour I just cut some panels out and do it again. They probably poured sloppy concrete on a windy day and the surface dried out too quickly, hence the spider web type pattern to the cracking.. Sealer doesnt fix cracks. The sawcuts look pretty far apart lengthways, should be under 3m spacings,. Driveways and Exposed Aggregate Specialists, Melbourne's Eastern and Northern Suburbs http://www.theconcretefirm.com.au http://www.exposedaggregate.net.au Re: Surface cracks immediately in new concrete driveway 22May 03, 2021 2:41 pm Rory I would never leave a customer with that for a finished job, however as far as your rights go, I think they are allowed to walk away from it as its non structural. If they happen straight after the pour I just cut some panels out and do it again. They probably poured sloppy concrete on a windy day and the surface dried out too quickly, hence the spider web type pattern to the cracking.. Sealer doesnt fix cracks. The sawcuts look pretty far apart lengthways, should be under 3m spacings,. I Urgently Need a Receiver/Business owner with Good Account for $2M Cash Wire Transfer Money is clean, coming from USA. let me know if you show interest, this is legit & direct from the bank WhatsApp +372 5376 3769 frankandreamartin@gmail.com It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 5254 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 32167 |
