Browse Forums Paving & Concreting Re: Outdoor tiles - How to check if they are sealed (or not) 4Nov 24, 2021 3:37 pm Romelo Only thing I have "tested" (accidentally spilled) is Seasol, which sat for about 5 minutes and was wiped off the tile, but stained the grout. Yes, the grout is never sealed unless someone went to the effort to seal it, which usually happens along with sealing porous tiles. You could do it if you wanted. There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2427 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1699 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98695 |
