Browse Forums Paving & Concreting 1 Jun 08, 2021 7:05 pm Hi all Looking for some urgent help. I had a concreter lay concrete at the sides of the house. He kept the 5cm gap around the house for weep holes but he couldn’t meet the requirement at 2 places. It was laid only last Friday (5 days ago). I have 25 years warranty on Rentokil home guard termite treatment. And my annual inspection due next week. My house is only 1 year 6 months old. 1. Would it affect my termite warranty? 2. Would they void the warranty saying it has been disturbed or would they propose a treatment to the area to keep the protection going? Anyone who has had a similar situation? 3. I m even happy to rip the concrete off first before their inspection but have been told that they will know that the concrete was laid anyway Please she some light. Pictures of the work attached [img:1cd79ltu]https://forum.homeone.com.au/u/80313_1623142992.jpeg[/img:1cd79ltu] [img:1cd79ltu]https://forum.homeone.com.au/u/80313_1623143078.jpeg[/img:1cd79ltu] Re: 5cm gap not kept underneath weep holes in pathways 3Aug 15, 2021 12:06 pm NCC-BCA V2 Class 1 & 10 3.3.5.8 Damp-proof course (b)The location of a damp-proof course or flashing serving as a damp-proof course, must be not less than— (i)150 mm above the adjacent ground level; or (ii)75 mm above the finished surface level of adjacent paved, concreted or landscaped areas that slope away from the wall; or (iii)50 mm above finished paved, concreted or landscaped areas complying with 3.1.3.3(b) (ii) and protected from the direct effects of the weather by a carport, verandah or the like; or (iv)in low rainfall intensity areas— (A)15 mm above finished paved, concreted or landscaped areas; or (B)0 mm above finished paved, concreted or landscaped areas if the damp-proof course is protected from the direct effects of the weather by a carport, verandah or the like. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7316 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5695 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11549 |
