Browse Forums Paving & Concreting 1 Sep 01, 2020 11:37 am Just wondering if I can install a plastic membrane under my footpath to direct water away from my house straight to a french or channel drain. I am having my retaining walls done right now but I have anticipated I wouldn't have enough resources to have my perimeter concreted as much as I want to. So I'm planning to just use compacted roadbase to slope away from the house and then put the plastic on top, direct it to a drain, add stepping stones and footpath pavers on top. Are there any plastic products that are durable enough for this purpose? Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20750 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 7302 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 5131 |
