Browse Forums Paving & Concreting Re: Thickness of concrete vs. mesh size 21Oct 30, 2014 8:37 am http://boostaoakfordsa.wordpress.com Site works: 26/8/14 Trench: 2/9/14 Slab: 8/9/14 Frame: 18/9/14 Bricks: 24/10/14 2nd fix: 24/11/14 Handover: End Feb 2015 Re: Thickness of concrete vs. mesh size 26Jan 28, 2015 9:55 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Thickness of concrete vs. mesh size 27Jan 28, 2015 10:45 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Thickness of concrete vs. mesh size 29Sep 11, 2015 8:19 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Thickness of concrete vs. mesh size 31Sep 11, 2015 6:11 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Thickness of concrete vs. mesh size 33Jun 27, 2020 12:26 pm Wirepower84 150mm 32mpa slab. Sl82 or Sl92 what would you recommend? Will have heavy machinery at times on slab. Probably SL81 but your engineer should specify. I would recommend to consider Cupolex system (cupolex.com.au) as it is can withstand load bearing pressure 6x+ of a standard slab (up to 100 Nm and with elastic response at 80 Nm!). And to achieve this you would only need 60 mm 25 mpa slab on top of 260 mm Cupolex with 668 mesh + D10 bars at 560 mm centers. MATE!!! I've checked their website and it's a 90% match at least. I've just called them and sent the pic through to confirm it's the same product. Thank you heaps. 3 7111 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 12232 It is so easy to do yourself. Even if you are not very handy. You literally only need a few basic things from bunnings. Honestly even with the most basic skills I know… 3 1393 |
