Browse Forums Paving & Concreting Re: Concrete around newly constructed house 6Jun 18, 2020 9:02 pm It is also best to incorporate a spoon drain on the side of the path, particularly if you are on reactive soil. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16143 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8824 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4848 |
