Browse Forums Paving & Concreting Re: Expert advice on broken internal drain pipes on slab 2Dec 02, 2019 8:15 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Expert advice on broken internal drain pipes on slab 4Dec 02, 2019 9:41 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Expert advice on broken internal drain pipes on slab 5Dec 04, 2019 6:09 am John0322 Hey everyone, we are currently building with Elderton Homes. We currently completing the installation of external drains. In the process, a few of our internal drain pipes (4) have been broken as in the photos. I would probably assume this would be from using machinery used to excavate on our slab. Is this easy to fix? what is the correct way of fixing this? should I get someone to inspect with CCTV to check if the cracks go all the way down under the slab? I don't just want this to be buried without proper fixing. This is our first home and I want to absolutely go back to the builder and insist on fixing this. help, please! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is what the builder has to say. Does this make sense or are they taking the easy way out of this? I saw from another post that they need to cut the concrete and replace the pipe. 2. The practice of reducing the drainage points within the slab back to slab level is a standard need, the pipes will when appropriate have an internal sleeve fitted and for some a reducer also. 4 6156 I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 15263 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4826 |
