Browse Forums Paving & Concreting 1 Oct 20, 2019 10:03 pm I have a question about specifying a concrete floor for a garage. We understand modern waffle pod concrete floor construction can get a bit thin. I work on my own vehicles and will be needing to jack up sometimes heavy 4WDs. Is there a preferred thickness and reinforcement required for said garage floors? Re: Garage floor spec 2Oct 21, 2019 1:14 pm Hi @D and As new home There are 2 issues the concrete slab thickness and the polystyrene void former beneath the slab Have a compacted sand pad put down and the 100mm reinforced concrete raft slab placed on that, internal beam midspan,etc. HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18019 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17220 bec of more thickness and underlay i prefer laminate. also my builder covers laminate only. 2 944 |
