Browse Forums Paving & Concreting Re: Driveway - screw piers 2May 02, 2018 7:39 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Driveway - screw piers 3May 04, 2018 12:21 pm StructuralBIMGuy Hi @Jacknife Screw piles also require Concrete Slabs with stiffened beams Is it standard?...NO is it very expensive?... YES Talk to the Council again & Look for alternate solutions BTW photos do help others Thanks for the reply. I challenged council and due to a technicality, was able to remove this oppressive condition! If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8315 How good is Simeon?! Always taking time to help others out! Wish we were building in NSW and could work together. Thanks for all that you do! 7 6573 DIY, Home Maintenance & Repair That’s very helpful information. Will find out more from there. Much appreciated. 11 13449 |
