Browse Forums Paving & Concreting 1 Oct 05, 2015 12:20 pm I'm new to DIY and chose to retile our laundry as my first project. The laundry room entrance is about 2cm higher than the rest of the house. When I pulled up the tiles it exposed a layer of concrete that was poured ontop of the houses foundation concrete about 2cm thick. I want to remove this layer. What is the best and easiest way to do this? Re: Removing concrete from on top of concrete. HELP! 2Oct 05, 2015 7:24 pm Is it concrete (with stones) or just a 2cm screed (sand and cement). It is most likely to be a cement screed. A Laundry is a wet area and typically would have a screed to provide falls to the floor trap. The easiest way to remove the screed is to hire an electric jackhammer with a spade bit, Dig down till you get to the concrete slab/screed layer then get down on your hands and knees and work the jack hammer along the line between the concrete and the slab. This should take less than half a day to do. Note, the laundry is a wet area and the new floor will need to be graded to the floor trap and a waterproof membrane installed. Therefore a new screed will be required. To avoid a step down at the door, some of the existing concrete (say 10mm) may also need to be removed. Re: Removing concrete from on top of concrete. HELP! 3Oct 09, 2015 6:07 pm Thank you for your reply!! I've bitten off more than I can chew probably, considering I have no trade experience. I think you're right and it's screed. Let's say I don't care it's a step up, Could I put more screed on top to make it even? Their is a drain hole in the middle I'll need to work around. The best advice is for you to get a competent building consultant to guide you through your build 7 4987 thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard 4 3355 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31732 |
