Browse Forums Paving & Concreting 1 Mar 26, 2013 12:49 pm Built with Beechwood Homes 2011. LakeView Lodge with Triple garage Building with Beachwood again 2013. Merlot with guest (investment) Re: painted concrete? would you? 3Apr 03, 2013 9:15 pm Built with Beechwood Homes 2011. LakeView Lodge with Triple garage Building with Beachwood again 2013. Merlot with guest (investment) Re: painted concrete? would you? 4Apr 03, 2013 9:22 pm Where you are coming from is where you are going to... Re: painted concrete? would you? 6May 04, 2013 5:41 pm Sounds like something we did a while back. You'd want to grind the adhesive off the floor properly, an acid etch definitely wont remove the tiling adhesive. We tried one of those thin concrete toppers, but like you said, they are no good. They just dont stand up to the wear and tear. Dont think you will ever get the colours matched of a coloured concrete slab matched to a sealer on another slab, for one the gloss and finishes will make them look different. Not sure a paint would help you but i used these guys in my garage and it came up good. www.2packepoxy.com.au Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 9027 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40949 Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and… 0 2767 |
