Browse Forums Bathrooms and Laundry 1 Jun 15, 2020 11:54 pm Our mosaic feature tiles are 8mm thick whereas our main tile is 10mm thick. I’d prefer if the tiles sit flush with one another. Is there anyway to pack out the mosaic tiles by 2mm to make them flush with the main tile? Can use more glue as they are mosaics and will be difficult to get an even surface. Any advice welcomed. Thanks Re: Packing out mosaic feature tile to sit flush with main t 2Jun 16, 2020 5:42 pm Use a notched trowel for your glue but use or make one with 2mm deeper notches than the one you use for your main tiles. I've done this a fair few times when doing bathrooms for clients. Stewie The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15791 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3260 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 752 |
