Browse Forums Bathrooms and Laundry 1 Jun 13, 2020 10:26 am Re: Remove shower 2Jun 13, 2020 11:38 pm 1 - Remove chrome covers on door hinges from the long flat side (they are 2 pieces clipped together) 2 - Remove the rubbers from top and bottom of doorway 3 - open glass to and on the bottom hinge you will see 2 covers in the bottom section that goes into the base frame. Remove screw caps covering screws 4 - While someone holding door from sliding remove the 2 bottom screws on either side of glass, gently slide the hinge on the bottom in the groove towards the large side of the opening ** Make sure door glass doesnt hit either glass panels 5 - When sliding the glass hinge at the base the top hinge will drop out of the pin from the top section be very slow and use 2 people. When you slide the hinge the top will disonnect and you can slowly remove the glass door 6 - At the mitred front corners there will be either small screws or rivets holding the corners together, could be inside groove, inside on rail or top, Remove these (if rivets use small drill bit to drill them out slowly) 7 - Along the inside long edges against the wall will have screws or rivets, remove these 8 - While 1 person securing the large fix panel tap by hand at the mitres to pop them apart, they should have 90 degree elbow inside frame holding them together 9 - Remove both panels and than remove the wall channels Re: Remove shower 3Jun 14, 2020 9:28 am Thanks Splashers will give it a go. It’s getting scraped anyway but could do without glass everywhere. Appreciate your time detailing the steps required How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6102 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12032 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7206 |
