Browse Forums Bathrooms and Laundry 1 May 09, 2020 2:46 pm Hi. I had the valve leaking. Not constantly, it was on/off. I changed it, how it is brand new. No difference. I googled: "Your water heater's relief valve can start leaking for one of two reasons: either the valve was triggered to open because of excessive temperature or pressure, or the valve itself is faulty. " In my case I have "Instantaneous gas hot water", so there is NO tank where pressure can "build up". Actually I do not even sure - why I need the valve at all. Any one can have idea - what is a reason for leaking? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Leaking Hot Water Relief New Valve? 3May 09, 2020 7:02 pm Why does the top of the valve say "COLD ONLY"? Re: Leaking Hot Water Relief New Valve? 4May 09, 2020 7:05 pm I don't even know why you would have a pressure relief valve there. If I'm reading all the pipe work correctly it looks like it is on the cold water inlet of your tempering valve? I wonder if you originally had a different HWS as all that pipe work is very messy and looks somewhat like a retro fit. I see you had another post that mentioned you had a pressure limiter on the entire mains water so I wonder if it was all aimed at limiting pressure for some reason. I'm not a plumber but I can't think of why that would be required and I'd be pretty sure you could just plug it. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Leaking Hot Water Relief New Valve? 5May 09, 2020 7:41 pm Do I see a double adapter? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Leaking Hot Water Relief New Valve? 6May 09, 2020 7:59 pm SaveH2O Do I see a double adapter? Good pick up. I'm sure it IP rated.🤣 Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Leaking Hot Water Relief New Valve? 9May 10, 2020 7:36 pm chippy ... another post that mentioned you had a pressure limiter on the entire mains water so I wonder if it was all aimed at limiting pressure for some reason. It was different house, and OLD one. This just 15 years old, pipes not not leak (yet). Re: Leaking Hot Water Relief New Valve? 11May 10, 2020 7:41 pm We were talking about the double adaptor plugged into the external power point. It's just funny that there is a waterproof powerpoint and a very non-waterproof double adaptor plugged into it. Like I mentioned in my post, I can't see why the pressure relief valve is even there. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Leaking Hot Water Relief New Valve? 12Jul 12, 2020 1:16 pm Got plumbers to service system. Result: Solar was connected. And the valve was needed. Despite being connected to town water pipe. Town water went to solar, warmed up, then went to gas heater. But they discovered problems with solar which just cost too much to fix. So they disconnected it and now gas heater connected direct to town water supply. I proposed them take the solar for free, fix and sell. Answer: useless from financial point of view. Bill $249. End of story. Re: Leaking Hot Water Relief New Valve? 14Jul 17, 2020 7:29 pm GGeorge551 The reason for your pipe faulty. No idea. Solar system on roof. I did not see it. House 16 yo, it may be a reason. I got suspicion the previous owner never services the system. DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6245 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6984 |
