Browse Forums Bathrooms and Laundry 1 Mar 12, 2020 4:59 pm Hi everyone. After some advice on repairing a cracked shower base (see attached). We'll be renovating the bathroom at some point so just after something that will work for us over the next 12 months or so. I've seen 2 approaches online that look to be either a fiberglass strip applied along the length of the crack, or alternatively a resin to be applied along the crack to bind the 2 sides. The resin (I'm assuming this is the right term...examples I've seen are from Selleys) is delivered through a double barreled plunger. Does anyone have any thoughts on whether these actually work and of so which approach would be better, or any gotchas on either? As I said doesn't need to last forever, but something that will hold and be functional for the short to medium term. The resin looks to be simpler to work with. Thanks Farness Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Cracked Shower Base 2Mar 19, 2020 8:58 pm You could go ahead with either just be sure you do the prep required. Also keep a very close eye on any water leaking, I assume you would already be getting some issues but you need to be mindful they cause significant problems in the structure. Best of luck Get on and Built It Re: Cracked Shower Base 3Mar 19, 2020 9:56 pm Thanks, no leaking to speak of as I felt the base crack when I stepped in before the water ran, and haven’t used the shower since. Speaking to someone today who recommended a mould resistant silicon sealant? Said it would be a soft finish but I assumed I would need to use something that set hard. The soft option would be easier but I’m not convinced it would work...? Cheers I have seen poly marble shower bases last in excess of 30 years 1 3042 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 3237 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 5186 |
