Browse Forums Bathrooms and Laundry 1 Dec 24, 2019 9:31 am We have chosen concave circular vessel basins in our ensuite that will mean our countertop vessel mixer taps will be a tight squeeze behind, so our site supervisor has suggested we can move them to the side at the rear (like 11 or 1 o’clock if it were a clock face). The question is, which side? We are both right handed if that makes a difference. Does anyone have photos of theirs and can relate how they like/dislike it? Many thanks. Second Time 'Round Re: Bathroom vanity tap to left or right of basin? 3Dec 24, 2019 11:37 am I am right handed and I am thinking of which hand do i usually use to turn on the tap and it is my right hand. So probably i will put it on 1o'clock so that my right hand doesn't need to reach to 11o'clock to turn on the tap. Maybe you can have a think and see which works? Re: Bathroom vanity tap to left or right of basin? 4Dec 24, 2019 11:51 am I'll try and find pictures of our last house, but if you are having double vanities then I'd put the left hand bowl at 10:30 and the right hand bowl at 1:30. That way it's symmetrical and keeps the inside section of bench clear of taps and more open Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Bathroom vanity tap to left or right of basin? 5Dec 24, 2019 1:53 pm chippy I'll try and find pictures of our last house, but if you are having double vanities then I'd put the left hand bowl at 10:30 and the right hand bowl at 1:30. That way it's symmetrical and keeps the inside section of bench clear of taps and more open On the outer sides sounds good, as there is more space between the bowls than on the outer edges anyway. I just haven’t found any photos to show it done this way. Second Time 'Round Transform your bathroom into a sanctuary of calm and sophistication with Hera Bathware's Bathroom Vanity Collection. A standout… 0 12269 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3639 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8049 |
