Browse Forums Bathrooms and Laundry Re: No floor waste in wet areas - problem? 3Nov 17, 2019 3:40 am judder We've moved into a double storey house, built I think early 2010s, probably 2013 I'm guessing. Unfortunately, the ensuite upstairs, bathroom upstairs and laundry (ground floor) all don't have floor waste pipes built in. I understand that for 99% of the time we are safe from flooding...the only real potential threat I see is the washing machine somehow leaking or the upstairs bathroom overflowing from the kids by accident. I'm not too concerned about the ensuite as it's just me and the Mrs and there is no bathtub anyway. Can this be retrofitted somehow? Upstairs I wouldn't expect an issue but the Laundry is a bit of a tough ask? It's a concrete floor. Thanks. It will smell. Regardless if it has the u bend. Re: No floor waste in wet areas - problem? 4Nov 19, 2019 1:05 pm "It will smell. Regardless if it has the u bend." Not true. If you have water in the floor waste you won't get sewer smells. They only usually smell when a not often used bathroom waste dries out. Stewie All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 2805 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 11655 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 13328 |
