Browse Forums Bathrooms and Laundry 1 Oct 28, 2019 7:57 pm Hi, I’ve started to pull some floor tiles up in small toilet only to find they were tile over tile from previous owners. So now in process of taking it back to original base. See photos attached. i’d like to now tile from base up but the overflow drain and toilet sewage will be at higher level. Wasn’t expecting level to be that much lower. is it straight forward job to get this overflow drain off and cut back pipe? Don’t want to damage it so have left going any further for moment. May get plumber in if not straight forward task. dont’t want to level back to the original depth if possible as then I can get ride of transition step (down) into next room thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Floor tiles - height of overflow drain 2Oct 29, 2019 9:20 am Jimmy2times Hi, I’ve started to pull some floor tiles up in small toilet only to find they were tile over tile from previous owners. So now in process of taking it back to original base. See photos attached. i’d like to now tile from base up but the overflow drain and toilet sewage will be at higher level. Wasn’t expecting level to be that much lower. is it straight forward job to get this overflow drain off and cut back pipe? Don’t want to damage it so have left going any further for moment. dont’t want to level back to the original depth if possible as then I can get ride of transition step (down) into next room Isn’t the bottom of the toilet pedestal at a similar height to the top of the drain? If you lower the floor level, won’t that leave the toilet sitting too high? Re: Floor tiles - height of overflow drain 3Oct 29, 2019 10:10 am Hey Jimmy2times Welcome to the forum You've got this covered 👍 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here Bosch Multitool It has 100's of uses! hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6250 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10474 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4546 |
