Browse Forums Bathrooms and Laundry Re: Shower niche depth 2Oct 11, 2019 4:01 pm Yes. Niche's are built by building it into the wall. Effectively there is no wall beyond the plaster board and tiles. Hence it will be the width of the wall - 10mm (plaster) -x for tile width 2-3mm ? So if its a 90mm wall it will be 77mm deep etc. So if its on a wall that joins the bedroom or another room there is no wall. If its on the outer wall (or if you request) they can't do that so they will build a secondary wall and place it within that. For which it will be any width you really want (but generally the normal wall width). but you are losing shower space unless that moves to compensate. Just ask, and make sure its listed as a variation. They normally accomodate. The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27283 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5404 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 |
