Browse Forums Bathrooms and Laundry 1 Aug 20, 2019 10:02 am Hiya. My son has just finished renovating my bathroom. He completely ripped out everything and started from scratch, including the walls and ceiling. Everything has been done correctly and the plumbing and electrics were done by tradies. Our problem is that the steam wont leave the bathroom even though we have 2 exhaust fans in there. 1 is the heat lamp with fan and the other is just a fan. We have 2 shower heads, but of course only use one at a time. 1 is a 30cm x 30cm rain head. The other is a hand held. Even when just the hand held is turned on, it takes less than 2 minutes to completely fill the bathroom with steam and the walls and mirror are dripping. Thats with both fans running. We have even tried turning the shower on with the bathroom door open to differing degrees, from just a crack to fully open, and the steam still builds up. It just seems to float straight past both fans. (Yes we have checked to see if they are sucking air) The bathroom is about 2.5 x 2.5 x 2.4. Walls are fully tiled. Floor is tiled. Gap under bathroom door. No shower door. Sealed window. (Were told that this was best to reduce mould as would make for better vacuum for fans) Any suggestions would be greatly appreciated. Thank You. Redballs. Re: Condensation problems in newly renovated bathroom 2Aug 20, 2019 10:19 am For air to escape, the discharged air has to be replaced but you have posted that you have accounted for this. The other factor is fan position. Where is the main fan positioned? You can hire a smoke machine to visual the fans draw, that might show something. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Condensation problems in newly renovated bathroom 4Aug 20, 2019 11:36 am SaveH2O For air to escape, the discharged air has to be replaced but you have posted that you have accounted for this. The other factor is fan position. Where is the main fan positioned? You can hire a smoke machine to visual the fans draw, that might show something. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15801 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 2182 I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 6683 |
