Browse Forums Bathrooms and Laundry Re: Condensation problems in newly renovated bathroom 2Aug 20, 2019 10:19 am For air to escape, the discharged air has to be replaced but you have posted that you have accounted for this. The other factor is fan position. Where is the main fan positioned? You can hire a smoke machine to visual the fans draw, that might show something. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Condensation problems in newly renovated bathroom 4Aug 20, 2019 11:36 am SaveH2O For air to escape, the discharged air has to be replaced but you have posted that you have accounted for this. The other factor is fan position. Where is the main fan positioned? You can hire a smoke machine to visual the fans draw, that might show something. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15773 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 1355 I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 6672 |
