Browse Forums Bathrooms and Laundry 1 Jun 29, 2019 9:05 pm All the bathroom videos I see are usually renovations with wooden/Plaster walls behind tiles and a wooden substrate under the floor tiles. I plan to renovate a 1965 2nd story unit bathroom but the floor is a concrete slab and the walls are brick & render, No wood. I am wondering if this is a whole lot harder and a more expensive bathroom to remodel. Re: Concrete & Brick Bathroom skin Remodel 2Jun 30, 2019 8:46 am david27 I am wondering if this is a whole lot harder and a more expensive bathroom to remodel. Only if you are intending to relocate plumbing and electrical, otherwise it should be pretty much the same. Re: Concrete & Brick Bathroom skin Remodel 3Jun 30, 2019 8:51 am If you are relocating plumbing and intend cutting the suspended concrete slab then you will need to consult an Engineer Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs We have a new build and need to clean bricks around a newly constructed deck. Need advice about whether to clean bricks with acid prior to oiling the deck, or should we… 0 2582 2 8320 |
