Browse Forums Bathrooms and Laundry Re: Need to find mounting system for 25mm copper exposed pip 2Jan 14, 2019 8:27 pm Amateur Player I am attempting to find a wall mounted clamp support fixture for 25mm exposed copper pipe - can find on aliexpress...see link below...sorry couldn't work out how to paste image directly. Would really appreciate if someone knows where I can get something similar to this in Adelaide. https://ae01.alicdn.com/kf/HTB1hvPORFXX ... 40x640.jpg Sometimes it’s not easy to find exactly what you are after, so you have to think laterally. Depending on how important it is, you could buy that one and have it copper plated. There are two companies that come up in Adelaide when you search on "copper plating". Other than that, eBay and Etsy are your friend, although ones that are very similar to yours pictured are made of brass, so I wonder if there is a practical reason for that? Perhaps copper is too soft for that application? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5107 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5832 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10892 |
