Browse Forums Bathrooms and Laundry 1 Jan 14, 2019 9:03 pm I am attempting to find a wall mounted clamp support fixture for 25mm exposed copper pipe - can find on aliexpress...see link below...sorry couldn't work out how to paste image directly. Would really appreciate if someone knows where I can get something similar to this in Adelaide. https://ae01.alicdn.com/kf/HTB1hvPORFXX ... 40x640.jpg Re: Need to find mounting system for 25mm copper exposed pip 2Jan 14, 2019 9:27 pm ![]() I am attempting to find a wall mounted clamp support fixture for 25mm exposed copper pipe - can find on aliexpress...see link below...sorry couldn't work out how to paste image directly. Would really appreciate if someone knows where I can get something similar to this in Adelaide. https://ae01.alicdn.com/kf/HTB1hvPORFXX ... 40x640.jpg Sometimes it’s not easy to find exactly what you are after, so you have to think laterally. Depending on how important it is, you could buy that one and have it copper plated. There are two companies that come up in Adelaide when you search on "copper plating". Other than that, eBay and Etsy are your friend, although ones that are very similar to yours pictured are made of brass, so I wonder if there is a practical reason for that? Perhaps copper is too soft for that application? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you. I’ve not seen these before, will definitely check them out at the Austral Display centre. 18 1587 Okayy....good to know as I might consider concrete instead. 2 810 I know it’s hard to tell from the photo but it’s definitely the pod. You can when see indentations from where things have bumped it. Sounds like it’s definitely… 11 1884 ![]() |
