Browse Forums Bathrooms and Laundry Re: Bathroom Lighting Design 2Jan 25, 2019 2:04 am Some ideas: 1) have LEDs to the both sides of the mirror instead of directly above. Generally works better and provides more even lighting. 2) making one of those lights above bath to support different colours, imagine water in your bath to go one day blue, another day green, etc. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28821 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8824 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8588 |
