Browse Forums Bathrooms and Laundry 1 Nov 12, 2018 10:06 pm Hi, Our bath tub has quite major cracks on the edges and where two surround wall join together. Also the some titles on the surround wall crack. What's the best way to fix this? Given the size of the crack, I don't think filler would work but do we need to knock down the whole tub surround and re do it? Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: crack of the bath tub surround 2Nov 18, 2018 2:11 pm You really need to investigate the cause. It seems that water might have got into the frame causing it to expand. You may need to remove the tiles and replace the wall lining under neath and then waterproof proprerly for a permanent fix. More caulking is just not going to fix the problem. Looking for some advice on pool surround planting. We have roughly 500mm wide garden bed around the edge of our pool. Depth of the bed is only around 250-300mm to top… 0 3856 Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9314 Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 24692 |
