Browse Forums Bathrooms and Laundry Re: Bathroom entrance 2Dec 05, 2018 10:04 am Hi Sembal, I can't find the exact maximum height online - if you search 'threshold' I think you may have some luck with a bit of digging. Even if you have this 'step' you can reduce it 'somewhat' by ramping doorway tile. Hope this helps! The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18568 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6164 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8443 |
