Browse Forums Bathrooms and Laundry 1 Nov 04, 2018 10:19 pm Hi All, Proud new apartment owner and I am hoping to put in a 2nd bathroom where I have shaded in the diagram (while pushing the kitchen to the left). I will get expert advice but wanted to know if this is something that is likely to be feasible. Any advice or experiences would be great! Many thanks, T Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Is a 2nd Bathroom Feasible? 2Nov 05, 2018 3:52 am tylergold123 I will get expert advice but wanted to know if this is something that is likely to be feasible. Any advice or experiences would be great! The biggest issue would be access to services like plumbing and electrical. Electrical and incoming plumbing should not be too big an issue if you have frame and plaster walls. Unless you have a cavity under your floors, outgoing plumbing would be the bigger challenge, but since the existing kitchen area already has that, it might make things easier. In the end, anything is feasible if you are prepared to pay for it. Re: Is a 2nd Bathroom Feasible? 3Nov 05, 2018 11:38 am Thanks, Don’t think it’s plaster walls. But I’ll have to move the internal wall to make space for the bathroom. I thought having it adjacent to the kitchen would make it easier given that all connects to the sewerage pipes. any idea as to cost? Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6062 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8368 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10372 |
