Browse Forums Bathrooms and Laundry Re: New bathroom price 2Oct 20, 2018 8:51 pm John1121 How much will it cost to convert a room into a bathroom? That is a "how long is a piece of string" question. Typically, a bathroom renovation will run from $5000 to $30000 depending of the quality of fixtures and finishes. Converting a room, however, will depend on how much of the existing infrastructure needs to be changes. If plumbing and electrical is already available and it has standard framed walls and a timer floor that is easily accessible from underneath, then the additional cost may be minimal. But if the plumbing and electrical is on the other side of the house and the floor is concrete and walls double brick or concrete panel, then you might be up for thousands. Re: New bathroom price 4Oct 21, 2018 9:39 am John1121 The room is located next to a laundry room and electric is also available so would be an ease. However the floor is concrete and really am just looking for an average design and quality. You'll need to get quotes from a couple of builders. The biggest issue will be running plumbing services through the concrete floor to the sewer. Re: New bathroom price 5Oct 21, 2018 12:12 pm arcadelt John1121 The room is located next to a laundry room and electric is also available so would be an ease. However the floor is concrete and really am just looking for an average design and quality. You'll need to get quotes from a couple of builders. The biggest issue will be running plumbing services through the concrete floor to the sewer. And how much will that typically cost? Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 3762 Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 5337 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 31773 |
