Browse Forums Bathrooms and Laundry Re: Help with my bad builder/tiler 4Jun 06, 2018 8:58 pm fifodad I should add that as its an insurance job it was a fixed cost and we were given a copy of the scope with costings from the insurer so we were able to see what the builder is being paid per item. Exactly - quote low to win the work and then spend the minimum to make the most you can. fifodad I can see a bit of a battle coming.... Good luck with it. Re: Help with my bad builder/tiler 5Jun 06, 2018 8:59 pm arcadelt fifodad I should add that as its an insurance job it was a fixed cost and we were given a copy of the scope with costings from the insurer so we were able to see what the builder is being paid per item. Exactly - quote low to win the work and then spend the minimum to make the most you can. fifodad I can see a bit of a battle coming.... Good luck with it. Cheers, sometimes you just have to dig your heels in and stand up for yourself. Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7028 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16130 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28259 |
