Browse Forums Bathrooms and Laundry 1 Apr 24, 2018 12:57 pm Re: Hot water system not working 2Apr 24, 2018 7:40 pm saahmadbulbul I just moved into a property and not sure how to turn it on. Gas and power is there. Nob is on position Any help? I can send actual photo when i get to home Thanks Is it plugged in? Re: Hot water system not working 3Apr 25, 2018 12:05 am Hi do you mean electric plug ? There is flushing red lights the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14074 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1406 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7552 |
